查看: 13|回复: 0
Plasma torch ?????????
发表于 2021-8-31 22:22:04 | 显示全部楼层 |阅读模式
Are the torch connecting fittings on Plasma Units the same so that the torch from one manuf. be interchangable with another manuf.?
Reply:Short answer: No.Long answer : Maybe. Some cheap imports are "clones" and may or may not use similar parts. There's no "standard" so unless you can match up pieces exactly or have the tooling and knowledge to adapt parts, don't expect this to work. Don't expect to be able to simply buy a Thermal Dynamics, Hypertherm, Miller torch etc and just plug it in to another machine and have it work. Not going to happen..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Mfg's do not like to make things that are common to their competators.  JGSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:On the pictures you have there most likey they are the same. Most of the chinese plasma cutter uses the M16x1.5 fitting on themwww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2026-1-1 11:22 , Processed in 0.122154 second(s), 18 queries .
