Need experienced airframe welder; separate fuel tank welder near San Antonio
发表于 2021-8-31 15:01:57 | 显示全部楼层 |阅读模式
I am planning on adding the float fittings to my Stinson 108 aircraft. The fittings kit is provided by the manufacturer with components and technical plans for welding to airframe at precise angles. I need a welder with experience working on steel tube airframes to do the job at my hangar near San Antonio.Separately, I need a welder to fix some leaks and replace some fittings on an aluminum fuel tank. The tank can be shipped, but I pefer to keep it in or near Texas to save on shipping costs and avoid hangling damage.If you know of anyone interested in the work, please PM me.Thanks,Brian Carter
GMT+8, 2025-12-18 16:22 , Processed in 0.071897 second(s), 18 queries .
