SA 200 Thermostat Removal
发表于 2021-8-31 22:22:02 | 显示全部楼层 |阅读模式
How do I get old stat out? It seems to have a sleave inside the houseing.Also what it has in it is a 180,is this ok or do I need a 160 here in south Tx.Thanks1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:Should come out easy enough.Would stick with the correct tempLast edited by Billy; 06-08-2009 at 04:21 AM.
Reply:I don't know what the book/manual calls for as to temp, but I just rember matching it up to the same degree at the parts house.Hillbilly Fabworks
Reply:I replaced mine a while back and as I recall it was a 160.My vintage equipment 1957 Lincoln sa 2001980's Lincoln 225 AC1952 F-2 ford truck1957 F-250 ford truck
GMT+8, 2026-1-1 11:18 , Processed in 0.097584 second(s), 18 queries .
