SAE 300 open circuit voltage
发表于 2021-8-31 22:22:02 | 显示全部楼层 |阅读模式
Does anyone know what the max OCV should be on the Sae 300 ?  I have a 1978 model. Thanks for any help.
Reply:If I had to guess I would say same as an SA200 which is 90 volts.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:is it not on the faceplate tag?Hillbilly Fabworks
Reply:The faceplate says 300 amps, 40 volts, at 60%.  At high idle, voltage control at max, voltmeter read 105volts.  Wondering if this was even in the ballpark.
GMT+8, 2026-1-1 11:20 , Processed in 0.076494 second(s), 18 queries .
