any feedback on mecanicapedrosa.com for hard to find parts?
发表于 2021-8-31 22:22:02 | 显示全部楼层 |阅读模式
I was able to find some hard to find Continental over/under size parts in stock at a website called  www.mecanicapedrosa.com.   I would appreciate any feedback or experience any has had with this site.  I found their staff very knowledgeable and helpful, but can't find any threads or reviews.tku  yz1.Just in case you found this thread in search of Continental Parts, here's some other sites I've looked at:wisconsinmotorscanada.caenginekitsonliine.com (very helpful) montesequipment.commandmsurplus.comparossmachinery.comrf engine 1.877.222.9649joseph.com foleyengines.com motorpowerinc.com (very helpful)continentalengines.com
Reply:Originally Posted by yz1I was able to find some hard to find Continental over/under size parts in stock at a website called  www.mecanicapedrosa.com.   ...Just in case you found this thread in search of Continental Parts, here's some other sites I've looked at:wisconsinmotorscanada.caenginekitsonliine.com (very helpful) montesequipment.commandmsurplus.comparossmachinery.comrf engine 1.877.222.9649joseph.com foleyengines.com motorpowerinc.com (very helpful)continentalengines.com
Reply:Followup = I was not able to find anyone who had prior experience with Mecanica Pedrosa, but did find that they were registered with, and had sold through amazon at some point, so, I placed an order with them for some over/under continental parts I was having trouble finding.They had a very nice selection and shipped a.s.a.p.    Their pricing and shipping were very reasonable and I got my order in just a few days.  In reply to "Noble" who emailed me about his Lincoln rebuild, I ended up buying ala carte from:www.mecanicapedrosa.com       Ask for Isel, she's knowledgeable and know these Lincoln motors. www.internalengineparts.com     they carried my valves instock and cheap.www.northernautoparts.com       Full Gasket set instock and cheap.These two guys were verrrryyy helpful but we could not find a complete kit with the over/unders I needed. www.enginekitsonline.comwww.motorpowerinc.com Yz1
Reply:Are we talking a Lincoln Continental, as in a car?If so, you have the wrong forum for that.This forum is for Lincoln welders.This should go in the mechanic's park forums!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Ken,Sorry, your probably right. It was probably wrong of me to assume that I could best find people who had experience and who could help me with my SA 200 overhaul in the "Lincoln" forum.  Both SA200's I've worked with had Continental 4 cylinder F-163 engines and the words "Lincoln Electric" emblazoned on them. So, I guess technically, they were Lincoln Continentals.  Sheesh. By the way, thanks for those who did steer me in the right direction.  Some of the F-162 and F-163 parts may be getting either very expensive or hard to find.  I can tell you, some of the best Lincoln Welder rebuilds I've seen were by people right here.  I probably would not have had the courage to try without seeing and reading about theirs. Mine won't be as pretty since I'm not getting the new decals, but I'll still be using it 10 years from now.    tks all. yz1
Reply:Originally Posted by yz1It was probably wrong of me to assume that I could best find people who had experience and who could help me with my SA 200 overhaul in the "Lincoln" forum.  Both SA200's I've worked with had Continental 4 cylinder F-163 engines and the words "Lincoln Electric" emblazoned on them. So, I guess technically, they were Lincoln Continentals.  Sheesh.
Reply:Originally Posted by yz1Ken,Sorry, your probably right. It was probably wrong of me to assume that I could best find people who had experience and who could help me with my SA 200 overhaul in the "Lincoln" forum.  Both SA200's I've worked with had Continental 4 cylinder F-163 engines and the words "Lincoln Electric" emblazoned on them. So, I guess technically, they were Lincoln Continentals.  Sheesh. yz1
Reply:No problem, just ribbin you a bit.Actually, up until I had to do my first tuneup, I really did'nt take too much notice what "engine" I had either.    I did have fun trying Joethemechanics compressed air trick to free the cylinders.  Then I did as Denrep advised and removed the "freed" pistons.  This allowed me to identify the cylinder with the collapsed rings.  The hardest part of the whole thing was finding the parts without losing my shorts. You know, someone here suggested filling the cylinders with kerosene and lighting it, now thats sounds a little like your Merc Comet. Duane, tks for the thought.  I try very hard not to breathe in or out too much.  If the wife finds out that I'm still breathing, she'll find work for me to do......
Reply:Believe me, I know all about trying to keep your shorts while doing a rebuild!I am right now in the middle of a rebuild on an Onan B43E on a Weldanpower.225AC/DC-CVGet this, I need a crank, found one new, for a mere $502.00, then add the most basic of rebuild parts, and add another $700.00 to $900.00, depending on what all I want to replace, and this doesn't even cover bearings, valve guides or seals or a carb kit! #1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Try stumpfweldingsupplies.com. If you can't find what you are looking for on their website, try calling them. They usually have continental parts in stock or can get them fairly cheap
GMT+8, 2026-1-1 11:20 , Processed in 0.110941 second(s), 18 queries .
