Sa 200... How do you separate generator from engine?
发表于 2021-8-31 22:22:00 | 显示全部楼层 |阅读模式
Guys as some of you know I am rebuilding my '67 redface Sa 200, and I have it down to where I need to pull the generator off the engine.  Anyone here can tell me how to go about this?  I have the owners manual for the machine, but the parts breakdown isn;t giving me much on how to get them loose.  It looks to me that there is a flex plate that bolts to the flywheel, but how do ya get to the bolts?  Any help is greatly appreciated.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:try this link you should find your answer here            Felon    http://www.aws.org/cgi-bin/mwf/board...pl?bid=44;pg=2Caution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:sorry should be  http://www.aws.org/cgi-bin/mwf/board...pl?bid=44;pg=1  first post           FelonCaution lurker lives here" hmmm That is serious,pass the ganja and pick up a  24 of MGD"
Reply:Thanks for the link!I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by Hammack_Welding... It looks to me that there is a flex plate that bolts to the flywheel, but how do ya get to the bolts?  Any help is greatly appreciated.
Reply:Forgive me, I think I was hungry and grumpy.Attachment 34577New plan; rebuild it, from grille, to exciter cap. Last edited by denrep; 10-19-2010 at 11:39 PM.
Reply:Well, I just got thru talking to the guy who does my welder repair.  He took a look at it today, and  we both agreed there was no reason to completely remove the entire unit.  If we pull the exciter and housing he has plenty of room to replace the bad wires.  Since there is some play in the bearing we are gonna replace it while we are in there.  That should put the generator in good shape.I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:Originally Posted by Hammack_Welding...He took a look at it today, and  we both agreed there was no reason to completely remove the entire unit....
GMT+8, 2026-1-1 13:15 , Processed in 0.135878 second(s), 18 queries .
