RE; preoil in governor
发表于 2021-8-31 22:21:59 | 显示全部楼层 |阅读模式
Rember when I asked about putting oil in a governor before you install it.Well I figured out where I read it ,it from Weldmart advertising a new governor it says it comes dry costumer to add oil.I'm sure there is a good reason for that .Just thought I'd ask
Reply:Yup.  Naturally it would be good practice to 'pre-lube' a new/rebuilt unit or one that has set for a prelonged period of time before installing as the one you mentioned in that thread and as I suggested doing for some initial lubrication as the governor parts are splash lubed from the gear train.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 11:22 , Processed in 0.110917 second(s), 18 queries .
