Really Rough WP225/ Briggs
发表于 2021-8-31 22:21:59 | 显示全部楼层 |阅读模式
Drove from CT to ME last night to get a $65 clunker, much rougher than the pictures on CL indicated. WTH , loaded it up and after tinkering today I was able to get the valves freed up and get compression, spark and even the starter cranked the engine. Carb may be the worst I have seen. Got it to fire on starting fluid injection, no carb, I know, very bad. Must have been in salt, guy I got it from said he did a salvage job at a building collapse and retrieved this unit. Cleaned Slip rings and have 4.8 ohms across them. If unit runs I will likely have to build and entire new enclosure. Dwayne , I though yours was rough till I saw this one , but I'm hopefull. Motor should be no problem, Any other electrical checks I cam make without it running?Hope to fire it after a carb kit , probably take a week or so to get. Looks to be a 1985 model year by serial and code. The floor of the enclosure as well as a couple of the upright inner dividers are toast , also the circuit and idler boards have been in the weather but look pretty well sealed up. Keep you guys posted. Attached ImagesLast edited by kolot; 06-16-2009 at 09:15 PM."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:WOW!!!!  Man, that is a project!  I wish ya all the luck on that one!  Looks like you are gonna need some sheetmetal and motor work.  Can;t wait to see the pics!I'm a Lover, Fighter, Wild horse Rider, and a pretty good welding man......
Reply:I'm toying with the idea of doing the cover in alum. diamond plate. got to see if she'll weld first. Many other projects have to come before this on though. Keep ya posted. Any one have anymore electrical tests I can do? Don't want to get to involved if it's not going to make sparks.               I'm on the rebound with this machine, I missed and SA400 , complete machine the guy parked after a bigger than normal job 8 yrs ago, motor was now thought to be stuck but complete unit, It was only about 30 miles away and the guy didn't get back to my email on CL in time, are you ready? The guy called me today as I sent him my phone #, he said the machine was sold and went cheap, How much?  $150 bucks to a guy that came all the way to MA from Texas. My wife was gonna put me on suicide watch.Last edited by kolot; 06-16-2009 at 10:41 PM.Reason: additional info"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Just when you thought you've seen the worse!CT to ME?  Takes me longer to get to San Antonio.Electrical checks you can do are:1) reactor for opens and/or shorts to frame2) stator leads for opens and/or shorts to frame and/or shorts to other leads3) check capacitors4) check field diode rectifier5) check DC output diodesThat's about it for now other than cleaning up the range and polarity selector switches.Keep us posted.BTW - the SA400 story really sucks!!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yup!That one looks like a challenge!Can't wait to see what you come up with for solutions on this one!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Man, that unit is in pretty rough shape.Was the owner storing it under water??Good luck on the renovation!Rex
Reply:Don't laugh about the underwater, when I first saw it and he had mentioned salvage, I asked him if it was on a ship somewhere that went down? He said no, but I'm beginning to wonder, maybe it was a State Hwy unit, stored in one of the salt sheds, or worse burried accidentally. always fun to get a good welder running for under $200 , will see."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
GMT+8, 2026-1-1 13:19 , Processed in 0.155345 second(s), 18 queries .
