Lincon mig.fluxcore mig-pack 180
发表于 2021-8-31 22:21:58 | 显示全部楼层 |阅读模式
thinking about buying this machine for welding up my trailer, atv trailer, bbq smoker and other small things around the houseHas anyone ever used one of these machines ? and if so could you tell me the pro's/cons pleaseIs there high frequency on it? so the stinger dosnt jump back when the wire hits the metal when starting the arcThanks very much in advance for your time and informationLast edited by then3wguy; 06-18-2009 at 08:19 PM.
Reply:Thats a good 230v mig welder.There is no high frequency on it as it is a dc power supply. High frequency is desired for ac tig welding aluminum. If the mig gun jumps back when you strike your arc, your wire feed rate is set too high.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2026-1-1 11:22 , Processed in 0.085421 second(s), 18 queries .
