how should I TIG weld this?
发表于 2021-8-31 22:21:54 | 显示全部楼层 |阅读模式
hello all,quick question.   Im working on this 18 gauge stainless steel sheet metal project.  I want to weld each layer together but do not want to see the welds.   I was thinking start with the bottom one, put the next one one and drill a few holes and tack them.  then do the same all the way to the smallest last one.  that one I could epoxy on.    thoughts?image by TDL028, on Flickr
Reply:plug weld from back sideEsab 253 mig welderHobart 210 mvp w/ C25 gasmiller 225 a/c stick welderO/A torchHF 40 amp plasma cutter
Reply:Yep, plug weld from the back. Drill holes in each layer except the top, work from the top sheet down (whichever layer is most "proud")
Reply:Plug welding .050 SS will see some distortion, 'wowing' of the sheet.Try some test pieces first.Alternative is bonding with Sika construction adhesive-polyurethane,available at H-D.Blackbird
Reply:Originally Posted by dave powelsonPlug welding .050 SS will see some distortion, 'wowing' of the sheet.Try some test pieces first.Alternative is bonding with Sika construction adhesive-polyurethane,available at H-D.
Reply:Automotive "Goop" is very good adhesive material.........zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I was thinking of the stuff that holds on rear view mirrors  ,might cost a little bit more than some of the other glues .Butt not much when I got some metal epoxy and it was $98  for a small can.
Reply:I've got a similar question relating to sandwiching 3 sheets if 1/8" for a welding table top.  Will start a different thread, once I've taken some pictures, rather than hijack this one.30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:1/8" hole and a 1 second blast of high current, no filler. 1 second max per hole.Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by MikeGyver1/8" hole and a 1 second blast of high current, no filler. 1 second max per hole.
Reply:I've got enough 1/8" surface rusted sheet to do a 5/8" table layered-up.    Same approach? Add 2 layers to the top sheet at a time?  Am only using one sheet now and it is pretty wimpy. Table is 30 x 60".  Spacing recommendation?Last edited by storeman; 09-11-2014 at 06:08 PM.Reason: Clarity30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:I'd just go with very small tacks on the edges of each piece...done correctly they'd be pretty much invisible.--Wintermute"No man's knowledge here can go beyond his experience." - John Lockewww.improvised-engineering.comManufacturer Agnostic:Blood----------Sweat---------Tears----|------------------|----------------|----Lincoln Red, Miller Blue, Esab Yellow
Reply:Originally Posted by wintermuteI'd just go with very small tacks on the edges of each piece...done correctly they'd be pretty much invisible.--Wintermute
Reply:use Sika flex 221 will hold them. this stuff is amazing. we use it at work to glue metal roofs on trolleys and the hold so this would be no problem
Reply:Originally Posted by storemanI'm concerned that with edge tacking the sheets will expand and contract differently in the stack.   Plug-welding or fusing from the center out to the edges would seem to offer a more stable table.Moderator, and OP, if it is time for me to move, please speak up.Jerry
Reply:Can you spot weld them? if not practice up welding your razor blades or gluing it
Reply:I'm gonna do a few tests.   Will post results.    Thanks again guys
GMT+8, 2026-1-1 11:18 , Processed in 0.103936 second(s), 18 queries .
