How many play pool?
发表于 2021-8-31 22:21:54 | 显示全部楼层 |阅读模式
Hope I don't get in to much trouble for posting some machine work, but how many of you play pool? And everyone who plays knows your suppose to make the pocket on the 8 so I made pocket markers for my team, they are made out of solid bronze that I polished, has the team name on one side and our personal names on the other and around the edge is all 15 pool balls + the cue ball in order hope you guys like them, and it took some time to make 7 of these..
Reply:Man, that is some nice work!!!
Reply:Yes, very very nice.
Reply:Very nice workThermal Arc 211iVictor torchesLots of grinders
Reply:Those are badass!
Reply:Would be cool if you could show us how you made them.how did you engrave around the edge?Show you set up please.Very nice .Jeff
Reply:Real nice work, although I don't play APA, I do like that rule. I play VNEA 8- Ball and 9-Ball.
Reply:I did it in a haas CNC milling machine, in a vice with aluminum soft jaws, had to flip the coin each time there where 16 flats around the coin.... And I flipped it on each side as and let it mill and engrave each side and then flipped again and did that each time... And it was time consuming,
Reply:Originally Posted by CJ_978I did it in a haas CNC milling machine, in a vice with aluminum soft jaws, had to flip the coin each time there where 16 flats around the coin.... And I flipped it on each side as and let it mill and engrave each side and then flipped again and did that each time... And it was time consuming,
Reply:Heirloom quality for sure! You blow me away with this.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Thanks guys! Much appreciated!
GMT+8, 2026-1-1 13:19 , Processed in 0.151009 second(s), 18 queries .
