New Style Collet?
发表于 2021-8-31 22:21:43 | 显示全部楼层 |阅读模式
Anyone see these?Scroll down to reverse collets. http://www.arc-zone.com/index.php?ma...oducts_id=8952
Reply:First time I have seen them. I may have to try them out. Could be a keeper.Good find!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:The only thing I see as a drawback is that since they clamp at the top of the collet body you lose some useful length  on the tungsten......also you may limited on a short backcap.
Reply:Reverse collets are far from a new design. In fact it's an old design and a very good design at that. They have 4 holes so they provide very good gas coverage. Pair it with a gas lens and you have a good basic setup.Because it grabs at the back your limitation is to a longer tungsten, I believe it has to be 3" at shortest. Being that it grabs at the back it pulls the collet out of the majority of the heat. Because of this you can get a LOT of use out of one of these. I mean YEARS AND YEARS.I have a few to sample for a 17, but switched to a 20 torch so I haven't gotten a chance to use it just yet.Edit: I forgot another very important and cool feature. Since it grabs at the back of the tungsten it's a 1 size fits all. Meaning if you use a standard 17 setup, 17 gas lens setup, pyrex, or stubby kit (stubby uses a short 17 collet) this collet will work for all of the above. No need to keep a short and long 17 collet laying around.Last edited by Gamble; 07-26-2014 at 09:59 PM.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I better stock up on these before inflation hits the collet market!  Next year they will be $17.99 ea, lol.  I'll take 1,000!  1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Originally Posted by GambleReverse collets are far from a new design. In fact it's an old design and a very good design at that. They have 4 holes so they provide very good gas coverage. Pair it with a gas lens and you have a good basic setup.Because it grabs at the back your limitation is to a longer tungsten, I believe it has to be 3" at shortest. Being that it grabs at the back it pulls the collet out of the majority of the heat. Because of this you can get a LOT of use out of one of these. I mean YEARS AND YEARS.I have a few to sample for a 17, but switched to a 20 torch so I haven't gotten a chance to use it just yet.Edit: I forgot another very important and cool feature. Since it grabs at the back of the tungsten it's a 1 size fits all. Meaning if you use a standard 17 setup, 17 gas lens setup, pyrex, or stubby kit (stubby uses a short 17 collet) this collet will work for all of the above. No need to keep a short and long 17 collet laying around.
Reply:I haven't been using my 20 torch for that long to compare. However I've only really worn out less than 5 collets or less since I have been welding. It would make sense the air cooled torches wear out collets faster because the torch gets hotter than water cooled and keeeps it out of the annealing stage. When the collet is hot and you tighten it, that is when they twist. I also use a wedge collet which are known to last a lot longer.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
GMT+8, 2026-1-1 11:26 , Processed in 0.111798 second(s), 18 queries .
