For Sale Miller Syncrowave 300
发表于 2021-8-31 22:21:40 | 显示全部楼层 |阅读模式
Looking to sell my Miller Syncrowave 300 Tigin excellent working condition,comes with foot pedal, 25ft tig torch, thumb control, heavy duty ground clamp with cable,voltage disconnect switch ( to wire machine from the circuit breaker the correct way) and is mounted on a dolley with heavy duty wheels to move it around.basically just add a bottle with some gas and your ready to start weldingthe faceplate is a little faded but you can still read all the dials and controls just finethe paint is faded as well but the machine works perfectmachine does AC and DC for steel and aluminum,goes up to 375 amp output, high frequency startsuper heavy duty machine,you could use this to repair cylinder heads, aluminum engine blocks, aluminum manifolds etc.Looking to get $2300 or best offer on it,I have seen similar machine recently sell on ebay for $3000 that come with no accessories, I easily have about $500 in accessories with the foot pedal, thumb control, tig torch, and ground clamp and cable, and the wiring disconnect switch,I will also throw in some 1 gauge 3 wire length of about 25 feet so you can wire into your electrical panel (this wire is not cheap by any means)runs on a regular 220 voltage line single phaseonly selling because I want to downsize and get something that is portableattached are some picsemail me at [email protected] if your interested I would gladly let anyone come over and take a look at it in personlocated in Seaford, NY
GMT+8, 2026-1-1 15:12 , Processed in 0.088765 second(s), 18 queries .
