Off Topic, Media Blaster Issues
发表于 2021-8-31 22:21:34 | 显示全部楼层 |阅读模式
My media blaster has pooped out on me, I took most of it apart & cleaned things, re-assembled still no work-ie! It is a Northern unit, in the lower $ range, do you al' think I should take it apart again? I have had very good results till now? Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:is it a gravity fed or pressure type kinda need more info what type of media are you using the gun maybe  just wornout
Reply:Black beauty, pressure feed. The blasted thing is only a couple of months old? The media doesn't make it out of the tank, slight amount of air at the nozzle, no media what so ever. I guess I'll be taking it apart again, more thoroughly this time? Any Suggestions Appreciated,Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:Sounds like you had gotten a little moisture in there and the media has clumped and clogged it up, this is common.Just take the whole thing apart and make sure there isn't any clogged up places, and you might want to either sift or replace the media!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:I stopped reusing the media the time before last, thought that might take care of it, but nooooo.Thanks Guys,Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:Try a smaller grit.  My small sandblaster prefers finer grit than black beauty.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Thanks David, I give that a go first.Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:How humid is it today in your locale? You can get a pneumatic vibrator that will cause the media to make it's way to the tank quicker. We have these on our glass and plastic cabinets and they work well.Bob.Miller Dynasty 200 DXMillermatic 211Hypertherm PM 600In Tool acquisition Mode
Reply:Bruce I have been thinking of getting one and just dont know. Are they worth it and how big of compressure motor do you need 18 cfm?1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:This is my first one, Northern Industrial, looks like a thirty gallon tank, eats a lot of air up even at 30 psi. I'm already thinking about a new (larger) compressor as we speak. My compressor is almost adequate, 5.6 hp, just ain't enough!! A larger one usually requires mo electricity than the 110 my shop now has.  My location, central VA, is mostly quite humid, above 70 %, this week, low sixties humidity, high temps though, mid to upper nineties. The vibrator sounds like it might be worth looking into?Thanks 4 The Input,  Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
GMT+8, 2026-1-1 11:19 , Processed in 0.099642 second(s), 18 queries .
