Lincoln Hobby Arc welder
发表于 2021-8-31 22:21:31 | 显示全部楼层 |阅读模式
Anybody out there know anything about the little 110V Hobby Arc Welder?
Reply:Just my $0.02,Over the years you can waste a lot of money trying to buy a welder for nothing.  None of these gimmick welders are much good for anything heavy enough to be useful.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:As Nitesky said!If you plan on using the welder for anything above welding a small bracket onto something, I would consider looking at buying something like a Lincoln Tombstone or some other equivalent welder as long as you are electrically setup for it!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:I was just wondering if it would be for the occasional small odd job. I have just purchased a Lincoln mig 220v unit but that is kind of hard to drag out in the driveway to do a 5 minute fix. Maybe I will just try to find a small inverter unit so I can stick weld some. I have my eye on a nice used buzz box on Craigslist local to me, just was think about a small 110v unit to have.
Reply:There is a lot that you can do with a 110 unit.Its like all tools, just make sure your matching the tool to the job!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2026-1-1 15:12 , Processed in 0.167080 second(s), 18 queries .
