shorthood won't stay pined
发表于 2021-8-31 22:21:30 | 显示全部楼层 |阅读模式
have a 55 shorthood that is still welding pipe with, great machine, the bellows ideler works fine, it ramps up with just a touch off the rod. problem is when i pin the bellows like when i need to use my grinder,after a couple off rods it will pull down past the pin hole and the pin will vibrate out then it will go back to idel, the pin will not stay in the hole, no one seams to know how to fix this??? any suggestions would be greatly appreciated as i have a pipe test monday.  thanks   Dave Pa
Reply:Put a slight arch in one half of the cotter pin to keep some tension on it while inserted in the hole?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:duanbe55, thanks for the reply but my shorthood still has the original round pin attached to a chain, but if i can;t figure this out I will have to start carring a cotter pin
Reply:I don't mess around with those pins. I put a vacuum switch in line with mine. I control mine from the panel.Joewww.CummingsHauling.com
Reply:joethemachanic, that sounds like something that would work great, but i have never heard off this befor. is this something you buy or build yourself? any info would be great. thanks
GMT+8, 2026-1-1 11:17 , Processed in 0.153785 second(s), 18 queries .
