I blame all you guys and your fancy tubes.
发表于 2021-8-31 22:21:28 | 显示全部楼层 |阅读模式
Got those stickers off the caps.This is what I had for the last 15+ years.Now I have these and spares and even room for more.Yeah there is some 4043 there.
Reply:clever...thank you for posting a pic with cover removed cause i was wondering "why he didn't do it one piece"you saved me from a future potential mistake
Reply:Nice. Good job.
Reply:They looks good - now where is the form-fitted tube rack painted to match your welder??  .....actually, I blame this entire website for every time I clean something and (shudder) paint something Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveThey looks good - now where is the form-fitted tube rack painted to match your welder??  .....actually, I blame this entire website for every time I clean something and (shudder) paint something
Reply:Originally Posted by SquirmyPugI found a few ways around paint.. 1.. Never finish the project.2.. Build the project out of free stainless scrap.. Because it doesn't need paint
Reply:I actually looked for red paint but couldn't find any, I had to use machine gray for the bare metal spots, the other bare metal you see is zink coated.
Reply:I don't use paint and just let it naturally turn into "industrial camouflage".MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I see I didn't post a pic of the side that shows all.
Reply:I like the rack - simple and effective Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:What no labels printed for thoseBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Really nice job, You have enough rods there to build an aircraft carrier: Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Don't go blaming me....Mine stays in the boxes......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Now you just need .045" in 70s-2 and 308, and some 1/16" 5356. Nice tubes.SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:That's no where near enough tubes. BTW, the best of paint on the plastic is just asking to be scratched. It's all well and good if you don't actually use the tubes, you know, just kinda keep them in the garage and fondle them on occasion, but if you actually use them, I think Duane has the better idea there.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Here are my "Fancy tubes" http://www.uline.com/BL_3657/Kraft-Telescopic-TubesTough as nails and less than 3 bucks each. I got the 2" x 36" case of 25 and gave half of them to a buddyLincolin Power Wave 450, Lincoln Powermig 255, Lincoln Pro Mig 140, Lincoln Squarewave Tig 275, Miller Big 40 G(with Hobart Hefty suitcase), Thermal Arc 95S and Esab PCM875 in an already full machine shop.
Reply:Originally Posted by BrazinNow you just need .045" in 70s-2 and 308, and some 1/16" 5356. Nice tubes.
Reply:Originally Posted by killdozerd11What no labels printed for those
Reply:Double post.
Reply:What's a dehumidifier?  Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by 7A749Always thought that was an easy way to make rod storage. I have the Rod Guard brand tubes with the O ring between the top and bottom piece. They keep moisture out OK, I mainly run a dehumidifier all spring and summer long tho.
Reply:Originally Posted by Robert HallWhat's a dehumidifier?
Reply:Been a long time since I've been around, but thanks for posting this idea, especially a pic with the open tube. Now you just need to color code the ends...BillLincoln v155-s with Tig Welder Ready Pack K2606-1One father's love of his autistic son www.inmyimage.com
Reply:Muggy here is 35%!!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Been hovering around 75% here this week. Continuous sweat SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/AMy filler has been staying nice and clean! Tubes have been working good. I just filled up on er70 again today $100 worth.
Reply:Where are you guys getting those flat caps instead of the domed ones?, I've looked at lowes and hd but no joy,ThanksMiller 252 Mig w/Spool GunMiller Dynasty 350 TigMiller 225 AC-DC StickMiller Spectrum 875 PlasmaOxy/Acet.
Reply:I got most of my caps from a local "Franks hardware". The others (needed more than frank had in stock) I got right down the road at Fleet Farm.  As you can see earlier in the post I turned the ends clean and completely flat on the lathe.
Reply:I like what post 17 put up but think these should have varnish brushed on them to seal them from moisture entering through the paper. The price is right. Just my thoughts,  Bob
Reply:Hey just found them at HD online they are furniture end caps-flat across the end for schedule 40 pvcMiller 252 Mig w/Spool GunMiller Dynasty 350 TigMiller 225 AC-DC StickMiller Spectrum 875 PlasmaOxy/Acet.
GMT+8, 2026-1-1 13:19 , Processed in 0.104930 second(s), 18 queries .
