查看: 13|回复: 0
trailer ramps
发表于 2021-8-31 22:21:28 | 显示全部楼层 |阅读模式
Friend of mine picked up a deckover trailer, had ramps but were not the correct ones for the trailer. He wanted the same ramp basically but larger. Came up with these.Miller ab/p 330Hobart champ 16Miller 140Lincoln Power Mig 255Lincoln SA-250
Reply:Looks good from here.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Nice looking ramps. I think that's the way I'm gonna build my ramps for my trailer. Good work. Chad
Reply:Ramps are tough to build. They are expensive, take a long time to build, and are either too heavy or not strong enough. Not uncommon for ramps to cost half or more what the rest of the trailer costs. Nice lookin set.Yeah, I know, but it'll be ok!Lincoln Square wave 255Miller Vintage mig30a spoolgunThermal Dynamics Pacmaster 100xl plasmaSmith mc torchEllis 1600 band saw
Reply:ramps look nice but what is he loading they do look a little lite ?But then I am used to loading 955 cats and stuff
Reply:they look long for the supports underneath..lot of free space. not sure of whats goin on it but they might bend towards the btm 3rd
Reply:Rungs are spaces too far apart.  Look pretty light duty.   Wouldn't want to load anything heavier than a pickup or mid size skid steer.Thermal Arc  Power-Tech 10/270  stick welderLincoln buzz-boxPurox O/A setupNothing is foolproof to a sufficiently talented fool
Reply:what is he loading? if it's tracked, I don't think you've got any issues. but if it's on tires you might have some issues with the spacing on the rungs. as for the cost of the ramps claim. I'm going to politely disagree. ramps are not that expensive to build, and it's not hard to build them plenty strong enough. as has been shown multiple times on different thread on this forum, by multiple people. Myself included. With the right design you can easily build ramps that not only exceed the weight requirements, but are also economical to build, and not overly burdensome to move around.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
GMT+8, 2026-1-1 15:12 , Processed in 0.097995 second(s), 18 queries .
