Here it is. Not Perfect, but functional. Some material was re-purposed (angles are from a hacked up bed frame)Attachment 847361Attachment 847371Attachment 847381Attachment 847391
Reply:Man your cart is awesome! I like the bottle mount.
Reply:I went through your posts and I like your fab skills and welds! You might want to make a new base for your band saw, I have that same model and have experienced some of it's downfalls. Again really nice work you do. Best regards, Bob
Reply:Originally Posted by rhuntI went through your posts and I like your fab skills and welds! You might want to make a new base for your band saw, I have that same model and have experienced some of it's downfalls. Again really nice work you do. Best regards, Bob
Reply:VERY NICE I like it !!
Reply:Looks like its built to the hilt. Only thing missing is lifting hooks.
Reply:Very nice. I like the way it looks like if you stood in the bottle rack it would look like a chariot. GravelThe difference between theory and practice is that in theory there is no difference.
Reply:I was expecting Charlton Heston to be around.
Reply:Thanks for the kind words folks. It is pretty heavy but she rolls smooth; no flex, no chitter chatter (not that it goes too far). I should have taken care of it before putting it together, but need to hole saw the tank saddles for filler rod tubes.It does have some semblence of a chariot don't it? Maybe some bridle lines and a winged helmet is in order!
Reply:Nicely done!*************************************Mike AccardiHenderson, [email protected] 250XLincoln Weldpack HDMiller Syncrowave 180 SD*************************************
Reply:Originally Posted by tackit. . . . metal and grinding always falls to the floor and I hate bending over to change settings . . .
Reply:My cart also uses two tanks.
Reply:Originally Posted by NicheFabIt does have some semblence of a chariot don't it? Maybe some bridle lines and a winged helmet is in order! |
