Sanitary Stainless Steel
发表于 2021-8-31 22:21:25 | 显示全部楼层 |阅读模式
Just curious if any other process is capable of producing food grade quality welds on Stainless steel besides tig?
Reply:None that I know of. Sent from my iPhone using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Probably about anything. You could splatter on a poo weld as long as you grind it smooth and passivate it afterwards.Welding/Fab Pics: www.UtahWeld.com
Reply:yup, what gyver said.    but....  food grade is a really broad term.
Reply:We use a process where I work (pharmaceuticals mostly) that is automated autogenous fusion. Punch in arc machine inc on YouTube and it will pop up.  Might as well be tig with no filler. Very repeatable, acceptable weld if you know what your doing
Reply:Food grade refers to a quality level used in the production of product for human consumption. Mainly used in brewing, juice factory, pharmaceutical and bottling plants. It requires 100% fusion of the internal surface of the weld joint. Mostly done on sch 5 stainless steel piping. Sent from my iPhone using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:After Adams comment, I should mention we typically only use that particular process for tube. Couldnt tell you much about said process for pipe.
Reply:When i was in college a company gave the pipe and instructions on doing food grade sanitary welds for them gas backed, no filler, 100% fusion,  flat on the inside, flat on the outside...The inside being most importantTakes practice to get the backing gas flow and pressure just right you taped the hose at one end and tape capped the other end the polked a small hole in that end too much and weld was concaved ...too little and it would be convex ...No sugaringFit up had to be real tight ...no gaps,no burrs,no offsetthey did fiber optic cam inspection of weldsI did it successfully and went and took their welding test and passed ...But the only openings they had were doing installs ...out of state  no openings at their fab shop here local ...oh well ...that was years ago...1990 somethingthey did a lot of contract work for coke a cola and campbell's soupBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:@ LeviC -  EBW ($$$) and LBW ($$) processes trump the weld quality on SS piping/tubing over the TIG (manual, mechanized/orbital) process. The power density and narrow beam created by the xrays/laser minimizes the weld HAZ and reduces Cr & Ni migration to improve corrosion control.Last edited by ManoKai; 12-07-2015 at 04:31 PM."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
GMT+8, 2026-1-1 11:18 , Processed in 0.236051 second(s), 18 queries .
