GMAW 2G v-groove on 3/8 plate 1/8 gap
发表于 2021-8-31 22:21:24 | 显示全部楼层 |阅读模式
I'll be doing a bend test, what's everyone's preferences when it comes to front-hand, back-hand technique for this application. Also, slow, medium, faster travel speeds for the cover passesSent from my iPhone using Tapatalk
Reply:Your best to use the technique that works best for you. I'm guessing you have practiced for this test?JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Using a drag angle will increase your penetration, reducing the risk of lack of fusion. As far as speed goes, slow enough that you don't get undercut, but don't let the cover get too high on you. Amanda
GMT+8, 2026-1-1 11:18 , Processed in 0.177890 second(s), 18 queries .
