onan performer 18 just shut off and now won't crank
发表于 2021-8-31 22:21:22 | 显示全部楼层 |阅读模式
Hi to Everyone,I'm new here, just looking for an answer for my situation.  I have a Ranger 9 with an Onan Performer 18.  It just shut down, like the switch had been shut off.  Now it won't even crank when I push the start button.  I've checked the oil, it is at the right level, I jumped the terminals on the oil pressure switch, still no go. Battery was dead earlier so I jump started it and started and ran for about 5 to 10 minutes.  I hooked up the jumper cables again and tried to start it.  I noticed the amp gage drops a bit when I push the start button.  Any assistance would be much appreciated.Thanks
Reply:One step at a time. Replace the battery. Try again.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:X2 on what he ^^ said.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Probably a stuck starter drive from attempting a low volt start. Turn the engine backwards a bit and don't try to restart it until you have a known good battery in it. Never, Never try to run an aircooled welder without a battery that wont hold a good charge. If its dead, charge it first. Unhook and THEN see if it starts. Otherwise, when in doubt... Test battery. The charging systems on those little rigs cant function without a good battery.
Reply:You have to go step by step, remove the battery and then try this.
Reply:Sounds like the charging system to me. Sense it ran for a few minutes and stopped after jumping.
Reply:Originally Posted by 12V71Probably a stuck starter drive from attempting a low volt start. Turn the engine backwards a bit and don't try to restart it until you have a known good battery in it. Never, Never try to run an aircooled welder without a battery that wont hold a good charge. If its dead, charge it first. Unhook and THEN see if it starts. Otherwise, when in doubt... Test battery. The charging systems on those little rigs cant function without a good battery.
Reply:Won't CRANK means it won't turn over right?Will CRANK but won't START is 2 different things.Does it turn over?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Hey guys.  Thread is a 1-1/2 years old that DonaldE dug up. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by zapsterWon't CRANK means it won't turn over right?Will CRANK but won't START is 2 different things.Does it turn over?...zap!
Reply:Originally Posted by duaneb55Hey guys.  Thread is a 1-1/2 years old that DonaldE dug up.
GMT+8, 2026-1-1 13:19 , Processed in 0.112718 second(s), 18 queries .
