here they are fellas,torch bottles for sale
发表于 2021-8-31 22:21:18 | 显示全部楼层 |阅读模式
i have for sale 2 sets of A and B size oxy and ace bottles for sale . these are owner bottles and can be swapped at Lampton welding or Linweld stores $400.00 per set 100% full call or text me and ill send pics 785 two 59 2one 38MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:WOW!  Near me new an MC runs $50 and a B is $75 filled in acet. O2 a 20cf is $69 and a 60cf is $117. Even my 75cf acet and my 80 cf O2 is still less than $270 total..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:i called around here this am and these are $500.00 new here so this is a steal if your around meMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:OUCH! SC prices are about what DSW posted. My condolences to anyone buying gas from an LWS in Kansas.
Reply:some more of that f&*king spam **** i guess ?MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:The A sized Oxygen bottle is 232cf, the B sized acetylene is 145 cf, so these are significantly larger than what you guys are talking about.  The A size oxygen is about $18 to refill and the acetylene is around $30 to refill here in ks. Read the whole post before bashing the op's price.  DSW, you compared a set of bottles of yours that's less than half the size of these bottles.In the field: '06 Ram 3500/Miller PP350    '14 F-350/Lincoln Classic 300DIn the shop: MM252, Hypertherm PM-85, White face MM200
Reply:thanks Hoff, i didnt hav the patience to try to explain to people what bottle sizes are !MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:In and around the North East, those bottles can only be leased and will not be filled or swapped at the LWS without a rental and deposit. Smaller ones can. I can't speak for your area as I don't know. I guess you would need titles to the bottles and current Hydro tests. I think my small swap O2 is either a 60  or and 80."Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:They're using a very unusual sizing system then. What you're describing is a K oxygen and a AC4 acetylene. As stated not normally sold though there are a few out there from years ago. I've never heard of a A oxygen at all (and I'm a reseller). The B acetylene is the second smallest bottle (the smallest being a MC).Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:unusual? if you were a dealer you'd know that the a and b bottles are the 2nd and 3rd size hi pressure bottles.  The sizes youre using are low pressure bottles. don't know how to make this any clearer, these bottles are the large size like you'd find on a welding rig or in a welding shop, not a hobby size.In the field: '06 Ram 3500/Miller PP350    '14 F-350/Lincoln Classic 300DIn the shop: MM252, Hypertherm PM-85, White face MM200
Reply:Ok I finally managed to find a reference to a A sized cylinder. Apparently it's what Scott uses. Never dealt with them before. Here's a comparison chart between companies.http://www.airgas.com/content/detail...=7000000000234 It looks like Airgas has changed there official designations because back when I was dealing for them they still called it a K. I also don't know where they got the Linde designations. I did have a old Linde catalog here that had the same designations as the Praxair list there but with much more info. Unfortunately it got burned in the fire.   Here's Praxairs chart.http://www.praxair.com/praxair.nsf/0/3615EA44C6E627D9852570A60005C9CF/$file/CylinderSizes.pdf  Notice in both cases that a Acetylene cylinder is not a high pressure cylinder. They have there own designations.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:regardless of what you call them, this price is cheap considering gas companies dont sell them anymore. it would cost over $500 to rent these bottles for a 10yr leaseIn the field: '06 Ram 3500/Miller PP350    '14 F-350/Lincoln Classic 300DIn the shop: MM252, Hypertherm PM-85, White face MM200
Reply:still have one set left they are empty bottles and ill take $350MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:iwill be headed for barttlesville oklahoma tomorow if someone down that way is interested in the last set of bottles.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
GMT+8, 2026-1-1 11:18 , Processed in 0.073192 second(s), 18 queries .
