Thermal arc engine drive Michigan
发表于 2021-8-31 22:21:15 | 显示全部楼层 |阅读模式
Thermal arc ta 10/270 power plus predator  $1850I'm selling this ONLY because I'm upgrading to something with remote amperage control.Everything works correctly on this machine. Most of it's life it was a stationary household backup generator that was set up for nat. gas or propane. It is very clean and not sun faded from riding around in the back of a truck. Yes, it does have minor scratches.The pros of this machine are;Honda gx620 engine (20hp)10,000 watts of 110, 220 single phase plus 10,000 watts or 460 3 phase (that's over 20 amps of 460)Auto idleBacklit fuel gaugeLow oil pressure shut downIt will weld 250 amps at 100% duty cycle in AC or DC300 amps AC or 270 amps DC only drops it to 60% duty cycle.It has a CV mode for running remote wire feeders (voltage sensing)It has a fresh oil/filter change, less than 400 hours on the clock, a fairly fresh battery, new fuel lines, and a new fuel filter.Here is a link to the owners manual;http://www.thermadyne.com/IM_Uploads...430429_493.pdfThis is not a "fire sale" ! I got a good deal on this when I bought it and am not looking to make money. Just looking to get something that will work better for me.Local pickup is ok, I can ship also. Last edited by welderboyjk; 05-30-2011 at 03:51 PM.Reason: Forgot pricing
GMT+8, 2026-1-1 11:25 , Processed in 0.073653 second(s), 18 queries .
