V12 Handmade motor fits in your palm!
发表于 2021-8-31 22:21:12 | 显示全部楼层 |阅读模式
http://www.wimp.com/tiniestengine/I put this in here as you can watch him make it .Watch it you will simply be astounded !RegardsBrettA good guess is better than a bad measurement
Reply:That was flicking impressive.  Wow.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:Brett, thanks.  Some real skill there!   Bob
Reply:That guy has some skills!Thanks for posting it.Buy American, or don't whine when you end up on the bread line.
Reply:Interesting, must be dieselXMT304 (school)SP125+ (home)HF 4x6 BandsawGood judgement comes from experience and much of that comes from bad judgement.
Reply:That take a lot of skill as well as extreme patience to assemble. It would be interesting to see him build something that this tiny engine can power, such as a boat, car or aircraft. Obviously it is only for display on the board it's mounted on but still it would be something to see it running a small model of some sort.
Reply:Originally Posted by BistineauThat take a lot of skill as well as extreme patience to assemble. It would be interesting to see him build something that this tiny engine can power, such as a boat, car or aircraft. Obviously it is only for display on the board it's mounted on but still it would be something to see it running a small model of some sort.
Reply:I think someone posted that in the private section..still really cool. Anyone see the mini Ardun that actually runs and sounds just like the real thing??Lincoln pro mig 180Lincoln Square Wave Tig 300/wp 20/home built water cooler Victor, Purox, Harris, O/A welding/cutting setupsVintage Craftsman drill pressVintage Craftsman/Atlas 12"x 36'' lathe7''x 12'' w/c band saw Everlast 140 st
Reply:Unbelievable!   That guy has patience!Lincoln AC225 & MigPak 140, Lincoln Magnum SpoolGun, Miller Spectrum 375-X Plasma, Syncrowave 200 TIG, Millermatic 252 MIG, Miller Digital Elite, General 7x12" horiz/vert bandsaw, 3' box/pan brake, 20 ton press, milling machine, 12x28 lathe, etc.
Reply:Originally Posted by T E BA Welder would be cool.
Reply:Thanks for posting. I will share with my class.Dave ReberWadsworth Ohio
Reply:Originally Posted by BistineauYeah, a welder would be cool, but where to buy the tiny tiny rods to use with it?
Reply:That Guy Is A True Master
Reply:Very cool!Miller Synchrowave 180 SDLincoln PowerMig 255Hypertherm Powermax 45Torchmate 2x2Victor O/A
Reply:amazeing,,,,,, more that skillfull, just incredible............The U.S. needs this guy......
Reply:Here is something to make you feel ham handed and impatient.:[ame]http://www.youtube.com/watch?v=5a1__niLIAQ&feature=related[/ame]
GMT+8, 2026-1-1 11:25 , Processed in 0.097721 second(s), 18 queries .
