PowerMig 216
发表于 2021-8-31 22:21:11 | 显示全部楼层 |阅读模式
I was wondering if anybody has ever welded with the PowerMig 216. I am possibly looking at getting a bigger mig machine in the near future and to the best of my knowledge the 216 is a newer model.http://www.mylincolnelectric.com/Cat....aspx?p=103906Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:You'll probably be one of the first as they just put that model up on the website.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:That is what I thought, but I figured I would check and see if anybody may have one already.Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:Ha, just at a quick glance it appears the 215XT is gone and the new 216 is in. I didn't do a line item stare and compare but it looks like the PM 215XT with a few mods to the case. Moved the on/off switch up where it should be, got rid of the passenger side door for consumables maybe and added that feature up top. Put that nice cable rack/gun rack on the side. Other than that I can't really say. If it is a rehash of the PM 215XT it's a pretty nice operating machine. So forgiving in the voltage taps it's shamefull ..  I guess the spool gun setup isn't as convenient as other manufacturers, but then I don't do aluminum so that isn't an issue to me. Could very well be for others tho. I got the 15ft, 250 amp gun as OEM with my 215. Kinda iffy with .023 wire, but then I don't bother with putting in the right liner either. I use another machine for .023 if I'm serious about it. So the PM 215Xt is a sweet machine, this should be too if they are similar.
Reply:So is there others out there that are happy with their PM 215? Thanks for your input Sandy.Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
GMT+8, 2026-1-1 15:12 , Processed in 0.102796 second(s), 18 queries .
