查看: 2|回复: 0
Weldanpower 130 engine runs wont weld
发表于 2021-8-31 22:21:09 | 显示全部楼层 |阅读模式
Hey guys, I just picked up a 130 weldanpower for $100 the engine runs great its a Koler this is an older model the code is 7500.I looked at the brushes and they seem to be fine, what else can I look for.I pulled the front cover to look at the brushes and there aint much esle in there,plus I dont know what to look for ,It was pretty clean no smell of any burned wire or broken wire.What next?I need some help. Thanks
Reply:If you haven't looked it up yet, heres a link to the owners manual for that machine.It can help in figuring out what is wrong with it!http://www.mylincolnelectric.com/Cat...t.aspx?p=30505As a guess, it may have lost its magnetism, there is a mention of how to re magnetize the rotor in the manual.Duaneb55 is about as close to the resident expert on that type machine, maybe he can come in here and help with it!Good luck!Ken.#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
GMT+8, 2026-1-1 15:16 , Processed in 0.068394 second(s), 18 queries .
