More on Weldanpower 130
发表于 2021-8-31 22:21:09 | 显示全部楼层 |阅读模式
I have one more question is there any site that would have any good pics. and lableing of the parts inside that generator housing.I've read a few fixes to try but I'm not sure what thing is what in there.The owners manule doesn't show much.Thanks for the help.
Reply:planton, did you check out the parts pages for the unit that you can download from the Lincoln website?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yea I did but there are no pics to speak of that I could find.I've found pics for bigger machines but not for this one.Either that or I just aint looking in the right place
Reply:What's your unit's code#?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Unit Code 7500 I belive its a 1972 model
Reply:OK, the parts breakdown http://content.lincolnelectric.com//.../parts/P74.pdf isn't what many of the others are but then there isn't a whole lot going on in there either.  Are you attempting to identify a particular component or just have the ability to identify any and all?The actual year is determined by the SN if you have that too.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 15:14 , Processed in 0.070370 second(s), 18 queries .
