Murex Transtig AC/DC 200
发表于 2021-8-31 22:21:01 | 显示全部楼层 |阅读模式
Hi guys. This has been sitting here for some time and doesn't seem to work...When powering up it all sounds fine, but about 4-5seconds in it trips the main RCD, its running off a 240v 32a supply.There is this part (I assume some kind of transformer?) which seems to be leaking some stuff all over, would that be the case or has something just been spilt on it? (Although with the case on I guess that is impossible...)Any ideas? Many thanks.
Reply:Welcome to the forum.Lincoln A/C 225Everlast P/A 200
GMT+8, 2026-1-1 15:15 , Processed in 0.168979 second(s), 18 queries .
