Copper Free Tig Filler
发表于 2021-8-31 22:20:59 | 显示全部楼层 |阅读模式
I'm curious if anyone has used the following:http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1I read some posts about AL cleaning, and someone mentioned that for steel filler they even go as far as stripping the copper off.The amazon link seems like a decent deal since shipping is free as well, and saves me a 30 min trip to the store.Any input greatly appreciatedMiller 350PMiller 30AHobart trekHTP Invertig 221
Reply:"...New proprietary copper free finish..." = rust. "USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Like Oldendum said, copper free rod rusts.  So store it in the house unless you're going to use it all very quickly.  Otherwise, it's fine stuff.  I have an old welding 'how-to' book at home where the auther sings the praises of copper free TIG rod.  For the amount of copper present, I can see it making a difference.  Certainly I've never seen a problem with any of the copper coated TIG rod I've used.Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Copper coated will rust almost as fast as copper free so I would never buy based on how fast it will rust.
Reply:I wonder if they have some other kind of coating on it. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:what is the advantage to using a copper free filler rod? Or mig wire?Millermatic 211Miller Syncrowave 350lx with cooler and tigrunner Thermal Dynamics cutmaster 811955 National Cylinder Gas O/A setup with original patina
Reply:Originally Posted by vwguy3Copper coated will rust almost as fast as copper free so I would never buy based on how fast it will rust.
Reply:The item in link is Italian rod Miller 350PMiller 30AHobart trekHTP Invertig 221
Reply:Its good stuff.Cant beat the price and free shipping right to my door.Can't beat that.
Reply:Duplicate
Reply:Originally Posted by shovelonYou gotta stop buying that Chinese stuff and go with the Italian rod.
Reply:Originally Posted by vwguy3My comment had nothing to do with country of orgin just trying to bust the myth that copper coated wire is copper coated to stop rust.
Reply:Myth? I'm not a metallurgist but I know copper dosent rust (corrode) like steel, even if it's sitting under an umbrella at the beach. Makes sense to me to coat with copper.. (Miss liberty is still standing after a century in the salt spray!) If I've got a nasty filler rod I just clean her up with a little sand paper and whala.. New filler rod!Just my opinion!Real welders know how to penetrate!(Equipment)Whatever can be used to beat my opponent into submission!
Reply:Try the Fe free version, you might like that better: http://www.cryoweld.com/wire-apparat...on-bronze.htmlSqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:I was told the copper coat was the lubricant for the wire DRAW die, and oxidation retardation was side benefit.Just a dab and fill welder not an expertEverlast 250EXMiller 250 SyncrowaveSharp LMV Vertical MillTakisawa TSL-800-D LatheGrob 18 in BandsawGreenlee cut off sawSanford surface grinderDeckel style Tool cutter grinderand 40+ yrs of etc,etc
Reply:Originally Posted by rick9345I was told the copper coat was the lubricant for the wire DRAW die, and oxidation retardation was side benefit.Just a dab and fill welder not an expert
GMT+8, 2026-1-1 15:15 , Processed in 0.111955 second(s), 18 queries .
