Lincoln L-50 mig wire
发表于 2021-8-31 22:20:57 | 显示全部楼层 |阅读模式
How does L-50 compare to L-56 regarding how the wire flows?Last edited by cope; 07-31-2014 at 11:48 AM.
Reply:50 is basic wire 56 has oxidizers to run dirty steel
Reply:I'm running 56 .030, it runs smooth for cheap lowes wire.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Originally Posted by Pavinsteelman50 is basic wire 56 has oxidizers to run dirty steel
Reply:Originally Posted by DanBoth wires contain de-oxidizers in their chemical compostion. The difference is that L-56 contains a high level of de-oxidizers then L-50. Alan (Cope), I've never ran an ER70S-3 wire  (L-50). All documentation I have on the different wire states that ER70S-3 will produce a less fluid weld puddle then ER70S-6. Some info I have is also makings it sound like ER70S-3 might produce a crisper arc then ER70S-6.
Reply:Originally Posted by copeDan, thanks.  I guess I'll find out Monday.
Reply:Originally Posted by DanAlan,Have you given the wire a try yet on your MM 210?
Reply:And besides who wears drawers when their welding.......don't we all wear azzless chaps
Reply:Only some of usBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Originally Posted by killdozerd11Only some of us
Reply:The choice of s-3 is usually specific based on need.Just speaking mig it's a more sluggish puddle with gas flux - open arc (short circuit), it needs a lot of Co2 if your steel has some scale or heavy oxidation. With spray arc it goes nearly as well as s-2 for appearance and is often used for multipass on heavy section. That's my take on what the weldor sees. If you are using Lincoln brand from Cleveland the s-3 (L50) feeds nearly as well as the s-6 (L56), both are very good with wire feeders.Structural and SAE guys often use it to get a DROP in mechanicals to avoid an overmatch condition as much as they can. That may sound funny but trying to drive the yeild point down to the mid 50'sksi has some real benefits if your parent material has a lower yield and tensile strength. If you PWHT you can get close to 50ksi yield and 70ksi tensile with very high charpy numbers, even with 100% Co2. The only fillers that you can get softer welds with are Lincoln L60 (EL12 sub-arc) and Lincoln L-S3 (EH12K sub-arc), but the smallest EL12 is 5/64" wire and the smallest EH12K is 1/8" wire so you won't be using them with a normal mig process.Matt
GMT+8, 2026-1-1 15:16 , Processed in 0.075078 second(s), 18 queries .
