Small Job For This Amateur!!!
发表于 2021-8-31 22:20:57 | 显示全部楼层 |阅读模式
Welded this up for a co-worker. These broke off . I guess I did ok. This looked to be cast aluminum. This was the reason for the thread on welding cast aluminum. Had a little crater trouble.........I will get there.Last edited by rahtreelimbs; 08-09-2014 at 01:53 PM.
Reply:Looks good from here.Nice repair.
Reply:rah; way to go. nice repair. what do you think of the 186? i got mine a couple months ago and swapped out the regulator(which started to buzz) with a flow meter and added a foot pedal. next is a lighter more flexible torch maybe water cooled. even though i haven't used the stick weld feature yet i like the machine.i.u.o.e. # 15queens, ny and sunny fla
Reply:I like the 186. Used my HTP 221 on this repair.
Reply:Nice repair.  How do you feel the 186 compares to the HTP 221 and the older 185 you have?
Reply:Originally Posted by docwelderrah; way to go. nice repair. what do you think of the 186? i got mine a couple months ago and swapped out the regulator(which started to buzz) with a flow meter and added a foot pedal. next is a lighter more flexible torch maybe water cooled. even though i haven't used the stick weld feature yet i like the machine.
GMT+8, 2026-1-1 15:12 , Processed in 0.073906 second(s), 18 queries .
