HI I am planning to buy a mig welder, can I get an advise on what brand should I take?I need a 220V machine and an amp around 140 to 200
Reply:Not going to recommend a brand, but if 220 volts get 200 amps mig. I own a Lincoln might for sheet metal and Miller for structural.I guess what drives brand for me is support. Find out who and where repair stations are and are they local to your area.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:You can't go wrong with Miller, Lincoln, Hobart or Thermal Arc. After that it depends on your budget.Miller Multimatic 255
Reply:If you go used, a Millermatic 200.New, I'd say a Millermatic 211 if youre a hobby guy with not a ton of heavy stuff to do.
Reply:I will say this, I constantly wish I had spent the $$$ and gotten a more powerful unit. If I were to do it all over again, I would jump right to the Hobart Ironman 230Miller Multimatic 255
Reply:I have tried them all and would say hands down the best is an ESAB Caddy Mig C200i. It does any excellent job on steel and aluminum.ESAB Caddy Mig C200iESAB Caddy Tig 2200i AC/DCFronius TPS2700Fronius TPS3200 with RCU 5000iHypertherm Powermax 85ESAB Powercut 400
Reply:I have too, and love my Caddie mig 200.. Still lots of good candidates in the 200 class machines. Try to stick with something that will push some .045 dual-shield wire now, and again. Even if at the lower-end it operating range./duty-cycle. It will open up another world.. If you don't need portable, try to get something that runs 12 inch spools of wire..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Almost bought the Caddie. Excellent machine. Opted for millertime 211. Like the MVP for small stuff when a 230 volt isn't available.
Reply:I'm new.... never welded before. I had it narrowed down to these five MIG welders from reading threads here; Thermal Arc 211i, Lincoln 216, ESAB 200i, Hobart 210, or a Miller 211. I read a lot of reviews online and took notes. All had similar warranties. I knocked out the ESAB 1st because I couldn't find anyone who serviced them within a reasonable driving distance. Next I knocked out the Lincoln because it appeared to be a comparable machine to the others yet.... was several hundred $$$ more expensive. Next to get the boot was the Thermal Arc simply because Tweco evidently bought out or merged with Thermal Arc and I was incapable of determining whether that would ultimately be a good thing or a bad thing for consumers. That left the Hobart and the Miller. The Hobart was a little cheaper than the Miller and there was a service center close to me so I initially determined the Hobart was the machine I'd purchase. Until.... I learned there were actual differences between the two.... Miller held it's value better than Hobart and the Miller 211 had a "dimmer switch" settings feature for current control that the Hobart 210 didn't have. I bought the Miller last week. There's a $100 rebate available right now that brought the price of the unit down to within range of the comparable Hobart, https://www.millerwelds.com/landing/...lue-Rebate.pdf. --I strongly suspect one can't go wrong with any of these welders. They're all quality and they've all got good warranties.MM 211Smith Tru Lite O/A set, Thanks Bob!Lincoln AC-225--But you must not change one thing, one pebble, one grain of sand, until you know what good and evil will follow on that act. The world is in balance, in Equilibrium- Ursula K. Le Guin
Reply:Depends on budget. Here are my two recommendations on mig.Budget: Hobart 210 MVP Bigger budget: HTP 200 I prefer a transformer mig over inverters.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer |
