Smaller mig gun?
发表于 2021-8-31 22:20:56 | 显示全部楼层 |阅读模式
I have a 250 amp Miller mig welder with a Magnum 300 gun on it. For what I need it for, the gun is way to big. I have a 175 and 100 amp Lincoln with Magnum 100 guns on them. I'd like to sell my 175, but I need the smaller gun for .120 wall DOM for roll cages.  Is there a physically smaller gun that will hold 200+ amps? What size is the Magnum 200? Thanks for the info!Millermatic 200Lincoln SP-100
Reply:I have the millermatic 210 with the M-25 gun. I find the size to be very good.It's my understanding that the mm250 came with that gun too - something you could check on.Then just switch back to the big gun only when you need it.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Put on a m10 or m15 gun and be done.And no the Lincoln magnum guns are not interchangeable.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GamblePut on a m10 or m15 gun and be done.And no the Lincoln magnum guns are not interchangeable.
Reply:Minnesota Dave, ypu think I could get you to measure from the nozzle down to the end of the handle of your M 25 gun? I bought the machine with it on it. Not sure how it was done.Millermatic 200Lincoln SP-100
Reply:Btw, this is a black face MM 200 if that makes any difference.Millermatic 200Lincoln SP-100
Reply:The welding supply company Praxair has a private label Bernard gun with the center fire tips called ProStar. Great little gun. It is a Bernard Mig gun. I had a 150amp model for years. I ordered and installed a compact 45* neck for it. It was very compact and maneuverable. The distance from your hand to the end of the tip is minimal. I have a 200 amp gun now on my PM216. Great setup.I'd suggest that 150amp Prostar gun for sure. or a Bernard. Same thing. Great deals on ebay for that stuff.Last edited by Jimmy_pop; 08-03-2014 at 07:44 PM.
Reply:Originally Posted by pcoplinMinnesota Dave, ypu think I could get you to measure from the nozzle down to the end of the handle of your M 25 gun? I bought the machine with it on it. Not sure how it was done.
Reply:Google says it came with a GA-20c gun. I'll have to look at it when I'm home tomorrow. I'm not familiar with the different connections.Millermatic 200Lincoln SP-100
Reply:I looked it up and the m-25 is listed to fit the mm-200Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveI was wondering about that, how did a lincoln gun end up on the miller?
Reply:Yeah, Miller says the replacement gun is a M-25. Does anyone know if the M-150 gun is smaller in size than the M-25, and has the same connections? Looking at the parts it doesn't look like there's a separate trigger wire/plug. Thanks all for the help!https://miller4less.com/info/pdf/201...uide_18-21.pdfEdit: The Magnum 300 is like twice the size as the 100. Way too big.Millermatic 200Lincoln SP-100
Reply:Lincoln sells different back end kits for the magnum guns so you can put them on all brands of welders, is what I had found out a while back.Thermal Arc 210 - Tweco 211I - Cutmaster 52
Reply:Originally Posted by pcoplinYeah, Miller says the replacement gun is a M-25. Does anyone know if the M-150 gun is smaller in size than the M-25, and has the same connections? Looking at the parts it doesn't look like there's a separate trigger wire/plug. Thanks all for the help!https://miller4less.com/info/pdf/201...uide_18-21.pdfEdit: The Magnum 300 is like twice the size as the 100. Way too big.
Reply:Excellent.  Thanks.Millermatic 200Lincoln SP-100
Reply:These come with a flexible neck option.http://www.usaweld.com/Miller-M15-MI...-m15-parts.htmhttp://www.usaweld.com/SearchResults.asp?Search=M-25Last edited by MinnesotaDave; 08-04-2014 at 10:30 AM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:The smaller Miller guns look like they might be the same gun that Hobart uses on it smaller machines. If this is true, the gun lead/whip has a touch of stiffness to it. The lead on the HTP Miller gun that I have has a very flexible lead.ESAB Migmaster 250 Hobart Ironman 230Multimatic 215TWECO Fabricator 181i & 211iHH125EZ - nice little fluxcore only unitMaxstar 150 STH - very nice
Reply:Originally Posted by DanThe smaller Miller guns look like they might be the same gun that Hobart uses on it smaller machines. If this is true, the gun lead/whip has a touch of stiffness to it. The lead on the HTP Miller gun that I have has a very flexible lead.
Reply:Originally Posted by GambleNo NO no. Stop trying to confuse everyone. The miller uses a .680 back end. MOST Hobarts (210mvp, 140 handler etc) use a .480 back end, SOME Hobarts use a .680 back end. 99% of Millers use the same back end connection, so you can use a m10 or m15 gun in place of a m25. And the other way around.
Reply:I couldn't find any Prostar guns that fit what I wanted on Ebay (150 amp 15 ft cable). I ended up ordering an M-150 gun with 15 foot cable for $140. Thanks all!Millermatic 200Lincoln SP-100
Reply:Holy crap you overpaidTorchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleHoly crap you overpaid
Reply:Eh not a fan of the oem stuff. The aftermarket ones are cheaper, more flexible and more comfortable.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleEh not a fan of the oem stuff. The aftermarket ones are cheaper, more flexible and more comfortable.
Reply:Flex 10ft miller gun is like $65 shipped on eBay.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
GMT+8, 2026-1-1 15:11 , Processed in 0.119852 second(s), 18 queries .
