lincoln weld pak 100 problem
发表于 2021-8-31 22:20:56 | 显示全部楼层 |阅读模式
the problem is that the wire feed speed is not consistent im running flux core the speed changes when welding   thanks for your time!
Reply:Measure the voltage at the drive motor and see if it ever drops. But my guess is you need a new tip and liner, it make as huge difference.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by Jack Kingthe problem is that the wire feed speed is not consistent im running flux core the speed changes when welding   thanks for your time!
Reply:Also make sure feed rollers are right size and make sure the little plastic wing nut stud that holds the spool isn't binding and tightening up the spool.
Reply:Sounds like a tension problem?Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:it has not been used much never adjusted the tension and the drive rolls arnt slipping
Reply:If you have the roller tension too high, flux core wire will squash and not feed through the tip properly.
Reply:Not being funny here because I know how frustrating it can be when equipment fails one.  But, I must say that those Lincoln weld "pak" welders are pretty much garbage.  A Lincoln "weld pak" is like a "6-pack" of Hamm's beer.  They both don't last long at all.  Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
GMT+8, 2026-1-1 15:15 , Processed in 0.072610 second(s), 18 queries .
