anyone help need a part (plasma torch)
发表于 2021-8-31 22:20:53 | 显示全部楼层 |阅读模式
i have a plasma to a hobart air force 400 and i need the torch w/ lead can anyone help at a good price?Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:it is the same torch as the spectrum 375 it is a 27c torchLast edited by assassin_works; 02-14-2012 at 11:37 PM.Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:anyone !!!Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:well then can any one tell me if i need the whole thing or can i just hard wire another torch to the lead since it was cut at the base of the torch ???Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
GMT+8, 2026-1-1 15:14 , Processed in 0.074917 second(s), 18 queries .
