My 68 SA 200 quit
发表于 2021-8-31 22:20:48 | 显示全部楼层 |阅读模式
My 1968 redface quit on me monday morning. I refurbished this machine this spring and its been running good ever since until monday. I was using a grinder when it quit. The motor runs good it just want put out any current. I went over to the machine put a rod in the stinger and touched it to the ground and nothing.  I cant figure out whats wrong with it can yall give me any suggestions i need my machine back welding soon. Thanks...
Reply:I found the problem and fixed it. It was a broken wire in the helmet end of the machine. Thank God it was something simple....Thanks Guys anyway...
Reply:Glad you found the problem so quickly Muzzy and that it was an easy fix.  No one ever likes a problem but you have to love it when it turns out to be nothing major.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 15:16 , Processed in 0.077338 second(s), 18 queries .
