Does anyone have a Weldanpower 130
发表于 2021-8-31 22:20:47 | 显示全部楼层 |阅读模式
I'm looking for someone with a weldan power 130 that could take the hood off and take some pictures of the selector switch behind the front panel and the reactor.I need to know where all the wires go I belive mine is wired wrong according to the wireing diagram I haveThanks
Reply:plandon,Did you get my response to your e-mail?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:plandon,Sent you another e-mail.  The Lincoln schematic showed me what's wrong.DuaneMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Yea Duane I just got it thanks,I'm going out to try to figure it out now.
Reply:Take a look at the side view of the switch in the parts break-down here Attachment 37158 and you'll see where the secondary wiper extends below the switch shaft.  You can also see how the tension spring is configured differently from the switch currently installed in the unit.  The correct switch PN M12449-1 is listed as obsolete so my guess is the PO installed another version thinking he could make it work.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, for some reason that attachment didn't work,when I click on it I get an invalid message
Reply:It won't open now for me either.  It was just this parts sheet http://content.lincolnelectric.com//.../parts/P74.pdf from the website.  Illustration I refer to is on the second page.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2026-1-1 15:14 , Processed in 0.100540 second(s), 18 queries .
