Weld aluminum with your lincoln weldpak
发表于 2021-8-31 22:20:47 | 显示全部楼层 |阅读模式
I have a weldpak 175hd Lincoln that I set up with a 100SG spool gun for welding aluminum with. If you are like me ,I do not want to play with liners in my steel welding cable.I built a spool gun control that can be installed in no time. As long as your welder has the same style welding tip that plugs into your welder,this will work for you. My controller supplys one set of dry contacts to your welder [two wires] to trigger the unit.I can build these units for 110.00 USD plus [email protected] Attached ImagesLast edited by mell1051; 08-12-2009 at 11:57 PM.
Reply:Interesting.  I've thought about rigging up something like this myself.------------------------------Lincoln 175HDLincoln AC/DC225Smith O/A
GMT+8, 2026-1-1 15:15 , Processed in 0.106335 second(s), 18 queries .
