Looking for starter for 62 Lincoln SA-200 Redface
发表于 2021-8-31 22:20:47 | 显示全部楼层 |阅读模式
I am looking for a starter for my 1962 Lincoln SA-200 Redface.  I have not been able to find one anywhere.  Does anyone know a source, or what starter would be used as a replacement as I am being told this starter is no longer available. It was a Delco Remy...I have checked with Napco also, & they do not know of a replacement starter.  thanks.Scott
Reply:See if the information denrep posted in this thread http://weldingweb.com/vbb/showthread.php...hlight=starter will help.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thanks for the response, but unfortunately that is the wrong starter.  Mine bolts toward the bottom of the welder.  I'll have to get a picture & post it.
Reply:Right, you have a low mount.  Check post #6.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I'd swear that the starter in the post you put up there Duane, looks just like the Delco starter that was on a late 60's Pontiac 400 from a Grand Prix I had in my old 1970 Pontiac Lemans GT!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisI'd swear that the starter in the post you put up there Duane, looks just like the Delco starter that was on a late 60's Pontiac 400 from a Grand Prix I had in my old 1970 Pontiac Lemans GT!
Reply:Originally Posted by denrepCongratulations , to another Pontiac engine transplant survivor.  The motor itself, and solenoid, is the same 10MT series as your Poncho used.Good Luck
Reply:I have one of the old style delco remy starters that bolts low on the engine, but it doesnt work  I got it with a bunch of parts and I tested it and it spun slow then stopped so It shouldn't be something real bad but it needs looking over. Id sell it cheap if you wanted it as a rebuild able coreMy vintage equipment 1957 Lincoln sa 2001980's Lincoln 225 AC1952 F-2 ford truck1957 F-250 ford truck
Reply:I don't know about other areas, but the starter/alternator rebuild shop here charges about as much as you would pay for one already factory rebuilt.They are good to use for hard to find stuff, but on something common, they are to expensive to use in my opinion!#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Originally Posted by Ken DennisI don't know about other areas, but the starter/alternator rebuild shop here charges about as much as you would pay for one already factory rebuilt.They are good to use for hard to find stuff, but on something common, they are to expensive to use in my opinion!
Reply:Call Stumpfs 618-566-4733, They got me a rebuilt starter for a little over $200.00
Reply:KAYE SELLON at BILL's welder repair Oklahoma city
GMT+8, 2026-1-1 15:14 , Processed in 0.073742 second(s), 18 queries .
