Useing dielectric grease
发表于 2021-8-31 22:20:46 | 显示全部楼层 |阅读模式
Hey does anyone know if its alright to use dielectric grease on the wipers of the switch on the welders,or even white grease. I use both on my electric cart that has the same type switch.The switch on my welder is getting hard to turn,just was wondering if that would work.
Reply:Myself, I'd prefer a dry film lubricant that doesn't attract dust/dirt.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:White grease/Lithium grease is good, no need for dielectric grease since these aren't dissimilar metals.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:With it turned off and unplugged clean the tabs with small stainless or brass wire brush or scotchbrite.  Lube the switch pivot that's most likely where the bind is.
Reply:plandon,FYI, I'm still trying to come up with a couple old switches to use to assemble a replacement for that obsolete version on your unit.DuaneMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, Thanks,the welder is working great,if you don't find one is not a problum
GMT+8, 2026-1-1 15:14 , Processed in 0.101199 second(s), 18 queries .
