I'm adding a micro start switch for my tig torch.2 wires out to the 5 pin female connector on the welder.I need to know the 2 contactor pins that are start and flow to get it going.A,B,C,D,or E.Any diagrams,scematics.Lincoln's web site is very limited
Reply:You might try contacting a Lincoln tech rep by email, he may be able to steer you in right direction. Did you check Lincoln's listing of operator manuals available for downloading in pdf form?A few of my toys !LinuxMintManjaroMiller Roughneck 2E Lincoln WeldPak 100HTP MTS 160 Chicago Electric 80amp Inverter Victor O/A
Reply:So far no luck with the manuals.I ran across the miller 5 pin on the web, but not lincoln.
Reply:What is the EXACT model and code number?Or you could trace them back.Lincoln trigger wires are usually 2&4
Reply:Tig 300/300Code No. 9609-CSerial AC 529635
Reply:Excuse me, wrong code number in last post.The correct Code No.is 8609-C
Reply:E & D is your remote arc start pins, so long as nobody has played with it.
Reply:Thank you Billy,I"ll check it out. |
