Hydraulic Press Mods
发表于 2021-8-31 22:20:44 | 显示全部楼层 |阅读模式
I picked up a used 20 ton hydraulic press on Craigslist, a few things were tweaked but overall in pretty good shape.Here's the press with the mods I made. I added a piece of angle across the back of the feet to brace up the frame and give me somewhere to bolt on casters. I also put on small pieces of angle on the front of the feet for casters. I bolted the casters on, I welded casters on once and I'll never do that again!I built some shelves out of angle iron and expanded metal to put on the back side of the press for tooling .I used 3/4" round for the upper shelf support.I made a holder for the jack handle from some tube and a piece of flat bar. No more missing handle!I made a handle for the release valve out of tube and a bolt.I notched the tube to fit around the pin on the valve.The two pieces of channel that you rest the work on weren't flat to each other so I got some heavier channel and welded up a new piece being careful to make them flat and square.After using the press for a while I found that using locking casters isn't necessary, the press stays put unlocked.
Reply:Nice upgrades!
Reply:Nice upgrades. I did some of the same things on my press.ChrisAuction Addict
Reply:Sent from my iPhone using Tapatalk
Reply:very very good idea this adjustable shelf, it can become a back gauge or material support etc...
Reply:I really like your upgrades. Good job
Reply:I like the shelf as well! I have pretty much the same press, I'll have to steal your ideas. 12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by VPTI like the shelf as well! I have pretty much the same press, I'll have to steal your ideas.
Reply:I have a similar press. 50ton. But I like the way you think!!!I can copy good ideas just like anyone else!Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Nice job making the movable shelf with the 3/4'' round.
Reply:Nice additions to a handy little press.
Reply:I have so much trash under my press that I haven't seen the base in probably 10yrs,,,, seriously"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice alterations. My brother in law installed an air hydraulic on his press, just makes things a little easierGeezerPower Mig 255C185 TIGBlue 175 MIGRanger 8 Kohler 20HP1974 5K Lincoln/Wisconsin Powered (Cherry)Victor/Harris O/AK 487 Spool Gun
GMT+8, 2026-1-1 15:14 , Processed in 0.099866 second(s), 18 queries .
