Welding table build thread. Yes another welding table!
发表于 2021-8-31 22:20:42 | 显示全部楼层 |阅读模式
Finally got around to building a welding table. We had these four 9 3/4" x 36" slats lying around the shop and decided to use them for a welding table. They are 1" thick. I wanted this to be able to roll around and be stationary so I decided to use a boat jack on one side and fixed casters on the other. It's not done yet but here's some picsBoat jackTabs for the slats up top. I threaded some holes in the slats. They are spaced 2" apart with 3" overhang around the frame.It moves so easily! (slats are not bolted on, just resting)Boat jack also folds awayIt's not done yet. I plan on having some sort of storage for TIG filler rod and clamps and what not. Possibly an expanded metal shelf.
Reply:Very coolMillermatic 210 & 300Miller 330 a/bp w/Miller coolmate 3Lincoln 225 ac/dc buzz box200amp Hobart 16hp portable welderCarbon arc torch, oxy/acy, plasma cutterCNC plasma table
Reply:Very nice, I like its compact size. Normally I would say do gussets in the corners but with its size I don't think that's needed.PROUD   AMERICAN
Reply:Nice Table*************************************Mike AccardiHenderson, [email protected] 250XLincoln Weldpack HDMiller Syncrowave 180 SD*************************************
Reply:Nice table. One of these days, I am going to have to build me a table. I'm too old for working on the floor.Qualified & experienced at welding scrap metal
Reply:Originally Posted by jaywoodFinally got around to building a welding table. We had these four 9 3/4" x 36" slats lying around the shop and decided to use them for a welding table. They are 1" thick. I wanted this to be able to roll around and be stationary so I decided to use a boat jack on one side and fixed casters on the other. It's not done yet but here's some picsBoat jack also folds away .
Reply:Nice table. The trailer jack is neat but I would have just gone with locking casters. Love the top tho
Reply:jaywoodDOAOpus
Reply:Thanks for the comments guys! Been using the table a bunch and it is very nice. Super solid and portable too
Reply:Been using the table for a bunch of different projects, still works very well. I welded up some rods on the sides of the table to hold misc clamps and welding helmets/etc.
Reply:Nice I would have spaced them out to clamp width for hold down. See it is fine no waterjet cutting or blanchard grinding needed.
Reply:Originally Posted by Fletcher94Very nice, I like its compact size. Normally I would say do gussets in the corners but with its size I don't think that's needed.
Reply:like the trailer jack addition. Wish I had seen this prior to building my new one.
Reply:Originally Posted by randyalike the trailer jack addition. Wish I had seen this prior to building my new one.
Reply:I would like to build one just like it! Beautiful job!!!
Reply:Some good ideas for your "pup" table there, it looks very useful and convenient, but curious how your shins are holding up after a year of knocking that table around? How tall is the table, did you design it with a specific purpose in mind or was that just how the scrap steel unfolded? Good work Jaywood!  When a welder tells you to "stick it", what do they really mean?"In a time of universal deceit, telling the truth is a revolutionary act." - George Orwell
Reply:Love the table the size is so handy for small stuff.  I will be the third to chime in about the shin knocker jack while it is a great idea , I would recomend  using a jack with the round weld on pivot as they can be removed with one pin pull. or use the jack with screw handle on the top  and fold out of the way .  But only time and your shins will tell how your's works . gxbxc
Reply:Haven't hit my shins on the jack once! I tend to keep it down and not flipped up sideways, so if anything - you hit the plastic handle which isn't bad. As far as the design goes, i just winged it with what I had on hand. I don't know the height off the top of my head but can check that next time I'm at work.Last edited by jaywood; 10-08-2014 at 12:15 AM.
Reply:Love the slats!
GMT+8, 2026-1-1 15:16 , Processed in 0.072779 second(s), 18 queries .
