Needing a Knee Mill Moved in the Indianapolis Area
发表于 2021-8-31 22:20:41 | 显示全部楼层 |阅读模式
Not sure where to put this, but I need a Lagun FTV2 mill moved from Indianapolis to a southern suburb.33 miles one way.Mill is on a professionally built wood skid.Banded / bolted / strapped and ready to go.Pickup location has a forklift.Drop off location doesn't.Won't fit in a f350 or 250. Already tried.Rough weight of 800lbs.Miller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:rent a trailer with a ramp....use a pallet loader and come along to roll it up and down the ramp...Last edited by roadkillbobb; 12-15-2015 at 10:40 AM.Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Call some local towing places and see if any have experience moving machinery. I had my mill moved by a towing company with a tilt bed truck. It was quite reasonableExpert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Rent a trailer and fork lift for the drop-off location. 800 lbs. is a very light weight mill...my Bridgeport which I moved 140 miles and rented a fork lift to remove from my flatbed is around 2200 lbs. The forklift rental was about $220 because I needed the forklift delivered out in the country 10 or so miles from town. Well worth the money and probably much cheaper that having the mill delivered to your drop-off location. Never used the forklift after unloading the mill from the trailer as I needed to do construction for a machine room first before installing the mill inside the room. Quite easy to move the mill on 2" or so short pipe rollers under the base of the mill on concrete floors in the shop. At 800 lbs. I would seriously try moving the mill off the trailer with an engine hoist and using pipe rollers myself. Buy some nylon lifting straps/chokers and don't trust lifting eyes on the top of the mill's ram...if your Lagun has them.EDIT: Or try DinahStevie's suggestion about the towing service. I grew up on forklift working for my dad and if you have no experience with them, bad things can happen. Last edited by WyoRoy; 12-15-2015 at 10:43 AM.Lincoln PrecisionTig 275Miller 251Miller DialArc 250Bridgeport millHossfeld bender & diesLogan shaperJet 14 X 40 latheSouth Bend 9" 'C'Hypertherm 900Ellis 3000 band saw21"Royersford ExcelsiorTwo shops, still too many tools.
Reply:Edit: Way more than 800lbs.  Silly previous ownersMiller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:Originally Posted by jontheturboguyEdit: Way more than 800lbs.  Silly previous owners
Reply:Try 2,800 pounds.http://www.lagun.com/products/ftv-2f...lling-machine/"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Find someone who rents drop deck trailershttp://www.fallsway.com/drop-deck-trailers http://i.ebayimg.com/images/i/161236...-1/s-l1000.jpg
Reply:Hats off to Dynasteve for the towing suggestion.  Found one local that's fair pricedMiller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:That's the way to go. I've had them move a lot of machinery for me.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Remember those are very top heavy and plan and strap down enough to account for that. 2800 lbs dead weight with a lot of it 4 feet of the ground can move a lot in a sharp turn or quick stop. Flip that thing and parts are probably not available at a  price you would want to spend.
GMT+8, 2026-1-1 15:13 , Processed in 0.102316 second(s), 18 queries .
