Not another gas question
发表于 2021-8-31 22:20:38 | 显示全部楼层 |阅读模式
OkBeen checking bottles in the shop and have a bottle of 75 25  brand new full up and a bottle of 100% argon And 2 full bottles of nitrogen.Now for the question.I was thinking of trading the bottle of mix 7525 for an equal bottle of 100% argon.Can I tig weld steel with 100% argon or do I need the mix.Note, I do not have a mig that uses gastrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Originally Posted by akphillI was thinking of trading the bottle of mix 7525 for an equal bottle of 100% argon.Can I tig weld steel with 100% argon or do I need the mix.
Reply:Thank youI will trade it in then.trailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:What do you the nitrogen for ???   Flux core mig, maybe consider going to gas ?  Lot cleaner then flux core and your liner last longer too. Just curious, I see you are in Alaska.
Reply:I use nitrogen to recharge the struts on my plane from time to timeI thought about stepping up with the mig  but sometimes does not work so well outside in the wind .trailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
Reply:Originally Posted by akphillI use nitrogen to recharge the struts on my plane from time to timeI thought about stepping up with the mig  but sometimes does not work so well outside in the wind .
Reply:It is a 175 cessnaWill have to get a pictrailblazer 302thunderbolt ac dc machine Hobart fluxcoreAHP tig 200x 2015
GMT+8, 2026-1-1 15:12 , Processed in 0.100963 second(s), 18 queries .
