O/A Welding Stainless Steel
发表于 2021-8-31 22:20:37 | 显示全部楼层 |阅读模式
Folks, I'm going to make a couple is small simple O/A welds on a piece of 3/16 stainless rod.  Not sure what 'type' of stainless.  This is NOT a critical or structure weld.Can I use another small piece of stainless to use for the filler?Do I have to use any flux?Thanks in advance,
Reply:http://www.hobartwelders.com/weldtal...tainless-Steelhttp://www.millerwelds.com/resources...g-how-to---try these 2 links for a discussion on the subject---Meltedmetal
Reply:MM, thank you for the links.  I think I have the info I need now to go and do this.Again, thanks!
GMT+8, 2026-1-1 15:11 , Processed in 0.110031 second(s), 18 queries .
