why does the stick catch fire
发表于 2021-8-31 22:20:37 | 显示全部楼层 |阅读模式
yesterday while practicing a few times the stick caught fire. is this because the current is too high? thanks
Reply:What electrode, what size, what amperage?Age of electrode, general condition of the flux?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:This sums it up pretty well, enjoy Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Originally Posted by Austin BennettThis sums it up pretty well, enjoy
Reply:6010/6011 will burn if you run them too hot. no big deal as long as the coating stays on.
Reply:Cuz there're effin hot thats why! 6010 is cellulose, and will burn. 7018, I'm sure has stuff in it that will burn as well.
Reply:Originally Posted by bikercatyesterday while practicing a few times the stick caught fire. is this because the current is too high? thanks
Reply:Originally Posted by InsanerideDid you prep with acetone and not let it dry? That happens to me even with 90% alcohol.  I usually dont notice til I lift my hood..   Thaat doesnt sound rite
Reply:Originally Posted by ANVILI usually wait a few seconds for the acetone and/or denatured alcohol to dry, prior to lighting up.  No issues that way.
Reply:Originally Posted by MagicHatFeynman was the best theoretical physicist of his time.  Lawrence Krauss has pretty much taken over that role now.
Reply:Feyman.  Quiet professional who relished the Joy in Findings Things Out.  Glad we crossed virtual paths 20yrs ago."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:I think you used too much ampereFor example, 130 amp stick should have , but you use 220 ​​amp
Reply:Originally Posted by walkerCuz there're effin hot thats why! 6010 is cellulose, and will burn. 7018, I'm sure has stuff in it that will burn as well.
Reply:thanks everyone.
Reply:Originally Posted by InsanerideSo you use alcohol? It is xceptable? I dont like acetone, it gives me a headache just thinking about and it costs more. I keep acetone around but would rather use alcohol. Alcohol is easier to get, it cleans wounds and I mix it with cutting fluid to keep sanitary but I dont think it makes me a better weldor.
GMT+8, 2026-1-1 15:16 , Processed in 0.111277 second(s), 18 queries .
