Techniweld mig wire
发表于 2021-8-31 22:20:36 | 显示全部楼层 |阅读模式
Anyone here use it? I bought 33 lbs of .045" er70s6 to try hoping for the best as it is lower priced than lincoln wire. Should be able to pass the savings onto customers. I've been using Lincoln L56 just not necessary for most of the non critical work I've been doing.
Reply:Yes.  It's a good wire.  It's not top of the line, but it works well for general purpose work.  No problems feeding.   Welds smooth for a cheaper wire.  I use it when my ESAB wire isn't available. (frequently out of stock).Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I've burned a couple of 11 pound rolls of .030 with no problems.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
GMT+8, 2026-1-1 15:12 , Processed in 0.073773 second(s), 18 queries .
