Regulator Died
发表于 2021-8-31 22:20:36 | 显示全部楼层 |阅读模式
My Victor AF150 Argon/Co2 regulator died today............seal(s) leaking badly.  I've been running straight CO2 thru it for several months............ran argon/co2 mix for several years before.  Someone told me the straight CO2 will freeze the diaphragm and cause failure.  Is this true?  If so, what is the best replacement so I can run straight CO2?
Reply:I did read that using a argon/co2 regulator on straight co2 will destroy it. It appears that you may have found that to be true. Here's one that was recommended on the site. I have not bought it yet. http://www.usaweld.com/CO2-Welding-F.../12020-co2.htm
Reply:BD: I ordered a flow regulator from HTP. It came a couple days ago.  I love it.  Thanks for info!
Reply:Originally Posted by BD1I did read that using a argon/co2 regulator on straight co2 will destroy it. It appears that you may have found that to be true. Here's one that was recommended on the site. I have not bought it yet. http://www.usaweld.com/CO2-Welding-F.../12020-co2.htm
GMT+8, 2026-1-1 15:25 , Processed in 0.097189 second(s), 18 queries .
